cmz829
well...... i pressure tested my system today and i seem to have lost maybe 3/4 of a psi in about 3-4 minutes is this normal? if it is that small of a leak would that cause my overheating? or does the pump lose a little pressure on its own i filled up to the top of the 15-16 psi cap range and its at maybe 3/4 of that range now.
even after 10-15 minutes it did not move at all from 3/4 so i do not beleive i am not leaking coolant
im waiting for a response from my buddy he helped and may remember more because a month or so ago the belt that was on there snapped and the crank dampener pully was shot if i remember correctly i think the water pump pully was a little tense which would explain why my power steering would get tight when stopped also correct? also when it is running warm and im stopped if i turn the wheel my rpms drop about 100 or so is this normal?
do you think the crank dampener being bad could have messed the waterpump up and caused this? if the waterpump was running below what it should be would it cause more coolant to be in the overfill?
