Car running bad after plug and wire change
Kona
Miami
I just changed the spark plugs (Motorcraft)and wires (Motorcraft). The car starts but has a slight missfire/backfire and seems to be a little off on the timming. It has about 50% power. I removed the intake to change the plugs. I cleand the intake,IAB, and T/B with intake cleaner. Befor changing the plugs the car was running poor at low RPM's, but above 3500 the car would smooth out and run good. Any help?
Jr's Sho
Moss Point, MS
Check the vacuum hoses and electrical wires on the back of the intake. Make sure everything is hooked up right. Do you hear a hissing noise from around the intake?
Kona
Miami
i wrote down the order of the wires but i may have got them wrong....no hissing noise from intake and i think i got all the connections on the back of the intake....
BeatDaSHO
Hatboro, Pennsylvania
here you go.
Cylinder Sequence
Firewall
1-2-3
4-5-6
Radiator
Coil Pack Sequence
Firewall
5 | 1
6 | 2
4 | 3
Radiator
Props to SDPatt
Greg
Kona
Miami
Ok.... Got it....thanks for the help...had #5 and #6 wrong on the coil pack...
Even me. The Chilton manual is wrong. I learned this one about 9 years ago.
