19FoSho92
today i fixed a blown fuse and put another new starter in my car cause last night it decided it wasn't goin to start. the fuse that was blown was tricky so i took the dash apart and checked the ignition switch, neutral safety switch, and all the wires. i had the battery unplugged for a lot of it but i did load it up pretty well with fuel. i drove the car around running like ass but it didnt clear up the check engine light came on when i first started it and it was idleing at 2000 but drops nicely to 900 when the iac is unplugged. then if the car isnt about 2700 if you put it to the floor it acts like it completely cuts spark and then around like 3000 it comes in and out but after that it has all its balls. the car did run fine before i did all this even with it not starting because i popped started it. Any ideas? also what is the relay on the firewall for?
