Car feels slow - Need more powa?
mattr66
I tightened up everything on the intake side, nothing was loose but doesn't hurt to check.
Went out and did a datalog on the SCT. IAT was showing around +10F over ambient.
Here are some pics from it, if you notice anything that looks off, let me know. I broke it down so it is easier to compare data points.
Boost over RPM, all runs are same data from 2200 to 6200 RPM. Seems to be between 13 and 15.5 psi throughout the pull.
51095750013 caec5b5b0e o
IAT over boost, coolant and RPM.
51095207206 1ba0f96be1 o
Line Pressure kPa over boost and RPM.
51095300987 81e323f438 o
Spark advance over RPM.
51095207171 bf5bffc92a o
Finally, my disappointing Dragy runs from today.
Chirped the tires off the line on the first run.
51095316077 0b4ffce3b0 o
51095764773 47fc757f99 o
I want to make sure I have everything on my end covered before I start bothering Matt.
Are you not brake stalling your car?
Sent from my motorola edge plus using Tapatalk
Ish416
Indiana
Put car in drive, hold brake and floor gas pedal, car stalls to around 2500 RPM, let off brake and keep it floored, pretty simple stuff. It also makes little to no difference with traction control on or off as the car rarely does more than chirp the tires.
The pictures I posted from the SCT stuff was just a 3rd gear pull from 2200 to 6200 RPM.
Anything I need to look over on my end before sending you the datalog?
Kevin81
USA
Uh...whats break stalling? Putting it in gear, hitting the breaks, then revving it, then dumping it on launch?
