Car cuts out.
bad_4dr_sho
Now what broke
Dickson, TN
Yes. After changing many sensors including the cam and crank sensor it still would bog down while driving, it felt like 2 cylinders just died. And then for no reason the power would come back. Turns out the dis was cracked. I threw one in from autozone for a 100 bucks no more problems. Hope it helps you too
ryan21288
Rhode Island
Picked up a DIS and a cam sensor at the junkyard today for free. Put them in and it still cuts out when i rev it. Im guessing it must be the Crank sensor is there anything else that could cause the problem before i go pulling everything apart to change the crank sensor.
93rev2sev
Hockeytown
see post #16
Or just unplug it and test drive it. If the bog is gone, you need a can of MAF cleaner, a screwdriver and 5 minutes.
114 is the ACT out of range - my experience is that the engine will run like crap until you fix that.
Don't know if its 'legal' to quote myself, but this ACT out of range must be fixed or the car will run like crap. There may be other issues as well, but every time I've seen this code, the engine acted stupid.
Westerly, RI
Weird. Shotimes lists the 126 code as CID, fordfuelinjection.com lists it as a MAP/Baro sensor code.
I've gotten the 114 code before in extremely cold weather, in both my 93 and my 92.
poffffd
