can't get the clutch pedal adjusted
kendal_jones
tha sho off
manchester ct
ok i replaced the clutch cable and now i really cant get it adjusted when i put it into reverse it buck like iam leting off to fast but iam not when i push up on the blue gear on the pedal it clicks 2 times and thats it and it still bucks in reverse can someone help me.
mlatten
Mons-taurus
Suffolk, NY
Well, I have the same problem. I think mine's the rear mount, but if yours didn't do it before then . . . a little trickier. As per the self adjuster (your "blue gear" I assume) just drive it around - a lot of stop signs and such. I don't suspect it is the cause of the bucking.
A few other things: Make sure the cable is threaded through the hole in the tranny and is unobstructed going to the firewall.
If you find the source - and your mounts aren't broken, please post. I'd do the mounts on mine, but there's snow now. If it's something else - that'd be awesome.
Good luck.
Minnesho
i was wrong
MinneSHOta
as far as i know the cable is self adjusting, just lift up on the pedal and it should adjust it.
mlatten
Mons-taurus
Suffolk, NY
Thinking the mounts are good is nothing like knowing they're good...Trust me. My mounts are so bad that the motor moves enough to put tension on the cable, causing the block to drop for a split second while the clutch is disengaged, but then jumps again when it comes back down - causing the bucking. Put your parking brake on and put her in reverse. If it moves more than you think it should, the mount has failed (when in reverse, the side of the engine closer to you will lift).
Also, is the cable the only think you replaced?
mlatten
Mons-taurus
Suffolk, NY
The cable length adjusts itself. That quarter procket ontop of the clutch pedal ratchets itself. However, if that piece is a little worn, and the clutch cable has any play, it could be it. So make sure all the ridges and still pronounced, nothing worn. If it looks shabby, the OEM part is $35. Easy enough to insall also. Best of luck.
Matt
kendal_jones
tha sho off
manchester ct
well my cable is brand new it just seems like iam leting off the clutch pedal to fast and the pedal is about less than an inch from the floor i just cant seem to get it 2 move in reverse like it use to do.
mlatten
Mons-taurus
Suffolk, NY
Is the cable the only thing you changed?
Does the car move at all when in reverse/bucking?
Does it feel/look like the car is bucking up and down or front and back?
Get a Chilton's and make sure the self adjusting assy. is put back together right.
