Can I put front struts from a 1995 ATX on a 1992 with no problems?
Jr's Sho
Moss Point, MS
I know I should get new struts but not now. The ones on my 1992 are completely shot. I now have two 1995's that I will be hauling off soon and I wanted to know if the struts from them will swap over to my 1992 with no problems. Question is do I have to change the spindles or anything else? Thanks.
Chris Benvie
Every so often
RedSox Nation
I don't think you will be having any problems doing that, because you don't have to swap the spindles the struts for the GEN1s and up are the same.. IIRC
Slo-Sho
It wasn't me!
Crossroads, CNY
As long as you have access to the 95 spindles, why not? You will need them if you ever plan to do a 96 brake upgrade. You said you have two cars, keep a pair and sell the other pair. I'm sure there are plenty of pre-94 SHO's that still have the puny little brakes.
poffffd
