What started out to be just a check to make sure everything was in time, turned out to be a cam seal fest
(I decided to tear everything down to replace all 3 seals)
Dumb me though. I took out the battery, engine roll dampener, both accessory belts, upper timing cover, intake crossover tube, and THEN I decide to loosen the crank bolt.
The crank pulley just spins when I try to loosen the bolt. I put a strap wrench on the pulley, but I can't budge the bolt.
MY QUESTION>>> Is it too late to try the "bump the starter" trick? Can I just hook the battery up and NOTHING else? I really don't want to start reassembling things just to loosen that bolt headbang
