JRA2000TL
The Complainer
I was reading over the SHO Phoenix Project website on the 60k stuff as I'll be replacing my left intake (upper front) camshaft due to a pitted lobe.
Do I have to do the starter bump and break the crank bolt loose and disassemble all of that other stuff as if I was doing a full front 60k? Maybe I'm missing something blatantly obvious and not thinking.....but after tearing apart the top end before, I think I can just loosen (or remove) the top part of the timing cover, remove the intake and vc, remove the 3 10mm bolts on the cam gear, slide the timing belt off, remove and replace the cam seal, reinstall the new cam (slipping the timing belt over the new gear), and bolt it on.
I'm thinking what I should do before removing the old camshaft is to use the ratchet on the crank bolt and line up both camshaft timing marks; then install the new cam exactly in the same position where the old one was.
Is there more to it than this? I have the 60k DVD as well that I'll have close by. I am NOT mechanically inclined but I have a garage now and want to try.
