sholando
We have a NEW source in the Eastern Region on Central Florida for CAM WELDING and overall SHO Maintenance!!! His name is Carlos and his email address is: [email protected]
He is a Master ASE Certified mechanic in the Palm Bay area (just south of Melbourne). He is offering the following service for $400.00:
WELD ALL 4 CAMS
ROTATE THE COIL PACKS FROM FRONT TO BACK
CLEAN THE INTAKE
IF IT NEEDS SPARK PLUGS IT WILL BE ABOUT ANOTHER 30-50 DOLLARS DEPENDING ON THE BRAND OF PLUG YOU WISH TO GO WITH
I WILL ALSO CHECK THE VALVE CLEARANCES.
I CAN PROBABLY GO 50 BUCKS CHEAPER IF PEOPLE DO NOT WANT THE INTAKE CLEANED.
Melbourne is a lot closer that Atlanta, so let's use Carlos and keep him happy!!!
Please contact him, and set up an appointment to have your cams welded. Please pass this on to any/all SHO owners in Florida.
Thanks,
Rob Lawn
WELD ALL 4 CAMS
CLEAN THE INTAKE
Thanks,
Rob Lawn
