Gen3 V8 SHO engine disassembly for cam weld - pictures
Qshiplvr
P Springs
What follows is my documenting the disassembly of my Gen3 ‘99 SHO motor for cam welding back in 2016. Since I’m not the mechanic doing all the hard work (JohntheSHOguy is), my descriptions may not be entirely accurate, but the SEQUENCE of photos should be accurate.
First, need to take off the cover, then the intake manifold.
GUxv92ysDJT6R6UgnfPhQHaDbzuACJ4adKvlJnxEAfOMJaVJAk
Start
Jo75eCmPisWK6TowAUCipeUdGqC264OafoLOhiBKWCekS0VW6Q
Appearance cover off
L6A3CGLxgCke9JnjZrNvP6qL0cSlyQtbB058lmARwvCQKq UHg
Appearance cover off, now wire loom appearance cover
5NWHcEyAb wmXg8sSmeLmgdmj I RM7zr7aMJKjICITuU2MC44
Use flat blade to undo the (brittle) tabs along channel
1qbviP TFplETk1PoRoiUCwRePXkoj7V3aYSMIcoVaSp9HnXzk
Unfasten the butterfly control square box IMRC (Intake Manifold Runner Control)
AsIUk4eRFKjmkomQrDFzxHzoYCkya3Yp6jgbgH0zFDq5gWL9zQ
Direct overview of IMRC square box unfastened
FOf2P5gOCwJhmm13tulyQLnUG56N TO8BZVHCdbjVXJoqAkObQ
View from passenger side of IMRC square box unfastened
D4AOESXxTD9YNGfQxezClUjGb99BmcM3MVIzJEKQ3Aw1PAkwtE
Removal of wire loom attachment point to get to front head
GRFPLKFox7FlqHcmlXiCqBs636U2v7 DUBmTE4yuc1xeuhNeyY
Disconnect factory hose clamps w/ needle nose pliers
7ZhJgbMnVkuD1S51b6PtL2sqg  mZpeU4EDy3pCb D3dp1UHAE
Hose loosened
JR9S o9zX7ADKS363UlwCixEslYGNwnbxLOjtBCLC285YQvRuw
Unbolt rear head intake
0xpKdAniyn9A3gRoxX0lKnb5ic8YiVoVA50MZPSyCEGeT505OU
Unbolt rear intake
MT5 rDg7DkvbI0JMCNYHLLEiXQExwAhjXWsFwoHi DoMOQ P U
Unbolt Rear Intake runner hose clamps
 8SYLcaIutYG0dGlpTqoyIwNNvVFYWAvzqpSr06 j5rnXSpqdc
Remove rear intake runner
QB5Vh4mCK0NGu6mIOQ2tUO0VosPNt5a7DkRH4UJ0SU2TmP4MvY
Use rags to cover intake runners so as to prevent foreign objects dropping into engine
MkKpcOaqti09T8cuk9ghmzLVJA9JZyPxu40uYbd8qOWw ZbSRI
Loosen inner track intake runner hose clamps
EoLBFdM3oMf0dncdLmc BxidpzprZakPx 9qZW5qSseOtJrUfo
Unbolt inner track intake runner
HxnVDKzmu4Kr0UMiJ1tgp Foa8GNe9Q0Pn15EmB776FZpWDHd4
Lift off inner intake runner
CKPZCGX1pr DW2HtMjblazteO4WXjB7MnV4gwuW9cuZR7FOyJc
Lifting off inner intake runner
XZBuoUdOOvVjn2MjN2Ow81yA8lNNeGT0dOe21zDv5tmBkvoDWc
Qshiplvr
P Springs
9 G3Ys28wbWxiA55tkW6KH719w QNiUDnN7oQsPc659Iv6pz5I
Half of the intake runners disconnected and removed
LQb105bxEYGRWGWG2Rg9Ho YFF2g1LacrYffprUWeJ4weIHc7g
Closeup of surge tank
RfxhQkNxSrI3XodGCh6PhRa35IkDyNyi2IfmTnlL3A47B tzOw
Start unbolting intake runners to front head
SPHrGFhWGZ4 nnNQOjMfpQO4 ZFijX3004nq2TJqVx4KH02JkA
Unbolting front intake runners
HiqwTCUCiLEjuTL4KYMcsdhHHk4EtnNx5JydrdqAdQjn 53e08
Three-fourths of the intake runners removed
MRiPKmaXtk3fIvSwM5NGR0s2EfGpZKzEg7iqiJTbZnzkNS3K94
Close up of surge tank
Gsp2yN3dXL238T6KOx0oOnoyw8Hj 7ePNPDY QxIMY5N ljRu8
ENf7G3eZlaU8uJdl0frMKtuuB3am9T1cc6ZoryVUpyZoQgCV08
Last intake runner removed
AxubPmFfed0ydlu1EPu2ck7j9lURRpGjSs1q H2riGrVy Wqv0
EEuAMZrcE0TMsYSmgx8aXa6AKTF3N1R16W49xJQ ohdhuZM6fs
Disconnect surge tank hose clamps
EzFbqVHjzgRqGzRMbHDh8IgZcX28CrGwhSvxjXdj0aCVUEdRlQ
Driver’s side view of surge tank
W9C1plfV3gU3kpGIE0AgA5to j8sWdN6pkKb9S0hdTt7RbLrSc
Unbolting surge tank
DdB2xk4kGBfvwOcPyt4ERsr 5wlHTMLHm8zDbGGAQ4yeDKYpYA
Disconnecting hose to rear of surge tank
ZVwM5syfhaww1LdIdztbTvaCBWRuyHmjc3jVFy6zUZGKPUMQyM
Rear surge tank clear
6j0wlxEdcdtout00JHz82BR7TIPFAqfzz9kW3lbIvPw9rv XxI
Unbolting rear surge tank
PI0w8uhRTr0xc8sLCnMzluf2hdGSOW IpcymppAQKVaTUdeYTk
Rear surge tank unbolting
H8OQ17mxnk76ahLuA07Lwx3mECVFu4HuGX yA2jeGFa FT7qh0
Surge tank ready to come out
KyNUhmW9QZCHFgB7nymSx6Eyo9CiZF7O2CZT9z4YxlNOOX1Iug
Disconnect hose to surge tank
UCYuAc l1QR9fsP6eSHFfOauaoE R IF2NDNulxBsA2rzD N20
Surge tank coming out
YloPvzRQ cAoIOc6HQlL6M7b7UMEWQX5Pm8 kiscqpT4bhWUdE
Surge tank removed - Rear valve cover exposed
Qshiplvr
P Springs
RIHnCCPbXJNjD5 vbR1OxIFZOEVRMa3rBcthHO6qlAOWgvGoj0
Surge tank out of the car by JohntheSHOguy
K7qecSyTsgcctKp6Im N5UufmYtXolinLs1nEXMm4 3MDRJUMo
Rear of the surge tank that faces firewall - this is what you need to unbolt blind
M08w04wXimTR6vbNuKIU4iJs1IzZH2K 3C5GQ7Ro3ou54VYyH0
Parts that came out of the SHO so far
EJMpZp8B2M1jGcApCyMB4MmtIgDgpblge dYR 7qX8Re31lbF0
Rear valve cover lurking under the now removed Surge Tank
CW0zerO0hBWt 9XLihAyELC17QCie9IsrutnV3FVeaUe JgkrM
JEw7SSI4KcvfiqwAZF1tXD8hyxJuwrcRNYwrkj8tm  3ApdHC0
Remove rear valve cover
ZZIkM7HZAuTruJV4p1KMoFM w3QPr3grDWrOSwxue33haufX U
Use rags to cover intake runners so as to prevent foreign objects dropping into engine (I can’t stress this enough)
LUJz67QSxyYB0UfElCyyTqAaIS9YK8kEzKC62xnQ 7dyoY1pIY
Take off passenger tire, inner fender liner to get to crank and pulleys
4WWrhm 26qL1bVRBw 9cM958RXBxtjrws3gw6eFz3ALvjFzQeY
Suspension and CV joint detail
Rc6YXc0yOTAj3qRMhco0PuBWwz7G4LVh7JWla5JFI G2d2MvDc
Crank pulley
VSj89beFanbdiCaip7xBf75EjKLtWzXog4Sbf wVNFlBaVwCBk
99 Front SHO strut detail and part number
E4bS40tMuSLMOk95JVqfwIO Agc4qQemOlECveAWKtg SGxGqE
Draining radiator fluid (must mention that JohntheSHOguy was in the process of replacing all fluids and adding a B&M supplemental trans cooler while the car was down for cam weld…I had just bought the car from previous couple who were neglecting the SHO due to new baby)
HD4UfzF9k2a0EywA1whhWMCwSdKs8l2HIZ2uDfTPpv2IQJVYO4
Radiator drained
QiadGEI56iMRa8AruQRZUfKKGnn5Q34zGqfxjdjsCOH 7IbVxI
Tensioner pulley (?) being removed
Ss0tlq1cRGhELAW6w60vebo49gnFUIu4hpiozXPsqW OxJoqLA
Pulley and bolt detail
5SEwoze2KlME p6lCo5YLL8Rt7KUk9qyBFwpsBYve9UASZkQqM
Power steering pump removal (part of all fluids refresh)
8qL QsJ0pBgjYzexgWGWvX9OxjsZvQ1esIffrCxE1ypBN pUcg
Pulley detail
PW5dod XSnU430a6PxYilxf0hM4o4U88qoOUNk76ABgR9cvyJk
Closeup oil pump pulley detail
15xZXii7QEwB2Enb zZZSrinkkZFcPtdJ8nhRMDWSpsPHjBCUo
Power steering pump space
Uc0I40hmMoBWJzaMwZv3ho13zkOkMqyhIdrwdN6IRF1pZDNN8o
Better access to “front” (i.e. passenger side) pulley side of the engine
Qshiplvr
P Springs
UzlDNXcq0HPkZ75RBWmlhE2moHZJd6Cdy3QCnIGvDWnwbrS7Ck
Removal of oil pump, removing wire harness plastic tract
VvaTci8kZo5EL9myolDdYVZQopeV066RIpb5EpclUShxGXs9ek
Exposing the dreaded “Y” coolant connector that WILL fail (becuz it’s made of plastic) if you don’t replace it with a metal one.
UqJx615pCfhhiXzz4eNpjR XzkCXA uRWoNq9ONnhlpbjH 5go
Like this one
FWQcReaPJWGXwKLhjn08O14kruGlmDENootmPZjUkNIFBC2o38
Closeup of OEM plastic “Y” coolant connector in engine valley
RldlUeYSSd44Pn0cZ6z2eFqN zN5yMXMvQj8kPt 4ivHg1Nt7E
Engine valley detail
QVbPl4JA9TZrxb2XdfBohhF3ALeOmdmdyke2Gr WbeHOWLPMV0
Oil pump removed, Front head coilpacks removed
OmLxxVRn GXoIg2O1zTW6VdoFoKyOe IBXSqlkWfEr0CX3aHMY
Moving wire harness out of the way
KIij6Xfz9nAFxvm5N0 gttC 4GVrvHPqufCqirYlKeOrAFb5XE
Removing front valve cover
7NxMFD 7MwqLcmmj13RfrvTaOl1IsodfmSU5OmbLU3oFq mkbg
Front valve cover coming off
LziCOZ oYAOZcGb23u1xthkfenif2fxInEtsBA Q7fst5keTyk
Driver side of front valve cover coming off
5FPRRb400imVjuWahjrCiXHZz9Tabgo8Nm2KeCKnWVHCkv4YoI
Front valve cover off, inspecting underside for any signs of sludge/burnt oil/shavings
RDb0NyNg 9HM9SKByQKJ8yeWrhfAav5SblfSpmuGV1RBrLxk64
Initial view of front head under valve cover
X76pNARgjTWx2C4HokDRt3uYk1DHZzUPqQRUslC9jcWmRkbkxQ
Front head camshafts UNwelded
ZaTCI5Xvu1p8HM8VTg4dWBCw7za9pVJZQaH8ryh8RkrpwcSyCE
Front head camshafts UNwelded detail closeup
TICj87eKqAuxtHcwc82Qp hVisVBPOfCRGXP9BdZ8euK8TPvtA
Front head cams overview
KXyhRGu7B2861srUVIGHU 1ZVXCoWh TeTrBmc Kjs43vs2jmU
Front exhaust camshaft UNwelded
G1zGCMZdVwolKL9mF2oqMozlXldYcm0vcASMC9TZgNRvs3Iuik
Underside of front head valve cover detail
7EtLusLEwReQoEbjjz0I0hGvfGAVfYIUxTffvBeXbGLMBXor28
 W4a8PHx28whNsOsivCDBvqn5sGUK EI1305OOOaXMpYXY HP0
Front head cams UNwelded
8HM  cgJi7iCzf I9qQdb4CThQIsXV76dbKkqvg8VBFC3A1M g
Front head cams UNwelded closeup
Qshiplvr
P Springs
NYDZCJpVN64KP0spb5awIutGiqxs3SyEILn3taJ9kMghhW0OjQ
Front head uncovered
XRZNgXpPW36z8KQu0HtELFFdENEwnzb33k9QXBzUJIS2EGL 3Q
Front head uncovered driver’s side view
KCnmyjQor1CVci9W6e6Uvc4FbJUhPPc5QUds16TORHQPPURDAA
Checking valve shim clearances w/ feeler gauge
At this point, I have to admit, we ran out of time (daylight) and had to stop documenting the rest of the camshaft removal process. Basically unbolting the caps and removing the camshafts. The next picture I have is of WELDED camshafts after JohntheSHOguy re-installed them.
WE7kpivjkg2CBe3EemGPx0hxE1YGmIXheXYUbZ0ZGzNFu5vgko
WELDED cams reinstalled
WMSn95bvc0FN9cCcK0b 8w6RljbFCYZqtnH9uaRQVNZSDiXpk0
Compare vs UNwelded
I hope this step-by-step pictorial will help anyone who needs to tear into their V8 SHO for any reason. I want to thank JohntheSHOguy for his expertise and friendship. I think mine is the 42nd cam weld he has done.
Jimmymac3467
