cam timing?
mccrash
ga
i got a 94 mtx and its runs like crap ever sense i changed the cam chain tenisioner on the left head .form what i understand if the marks on the cam chain sprockets are faceing outward lined up flat with the outsides of the both heads.the cams are in time and then install the timing belt gears on the cam.then line the marks up on the timing cover and the sprockets and the crankshaft gear and thats it.its in time.o by the way the white painted marks on the cam chain are gone.if i left any thing out please tell me.
93rev2sev
Hockeytown
I have no idea but "bump" for visibility...I need to know how to set up cams too.
SHOtimer
#2910
Santa Clarita, Ca
This motor is extremely easy to time, if you know how. But, also easy to mess up if you don't know how. The nice thing is that it is a non-inference motor, so if you do screw it up you don't damage it.
Here is a link to the AZ site that shows you how to do it. Scroll down to the SHO motor and it is pretty self-explanitory.
http://www.autozone.com/servlet/UiB..._us/0900823d/80/0b/f8/0a/0900823d800bf80a.jsp
Doug
haydenm315
Reisterstown, MD.
you are correct that the dimples on the sprockets should line up with where the valve cover gasket mates. They are 180 degrees from eachother. The autozone procedure covers it well.
To be sure you are correct, the timing chains have odd colored links on them. The procedure says they may be colored white. They may or may not be easy to see, probably not. It may be very difficult to see these links. Don't give up, you should be able to find the marked links. I know I had trouble at first but then found them.
Off Road SHO
Moderator
If the chain marks are gone, here's an easy way to know if you have them right. There is a "tight" side and a "slack" side to every drive belt/chain/rope, whatever. The tensioner always rests against the slack side. With the tight side tight, the dimples should be on the outside of both sprockets and even with the edge of the head.
Tom
