Cam Sensor
davidkristinab
Missouri
Getting ready to replace cam sensor. All data says to pull off a few things. Its a 93 3.2 is there an easy way to do this?
Pretty easy - disconnect the wire, remove 2 small bolts, remove cam sensor. Assembly is reverse.
davidkristinab
Missouri
ok thank you, so you dont have to remove any pullys like it says? And how do just say thank you in the post cant find a way.
expy916
sacramento
Its an ATX, should be easy. I had to do it to my MTX (I have huge hands) and the PS belt, tq dampener, ps reservoir, crossover tube, and top timing cover had to come off.
Redneck1465
Indiana
No should be real easy. On my MTX I had to remove the the crossover tube and unbolt the dampener but other than that I could get right to it. Real easy job to do.
313tiger
