Cam position sensor
goalieman59
Learning Slowly
OFallon, IL
Just got the car back from the Ford Dealer they said I need a new Cam position sensor and syncronizer. Can any one tell me how to do this my self? When I scanned the car I got a 214 code which is the CID not the cam sensor any ideas?
Jason
SRGUYINDAVIS
Davis, CA
cam position sensor is relatively easy. Just two small bolts and a plug to pull it out. It is located in the back left corner right in front of where the ecu comes through the firewall
Black '93
Guest
Lakemoor, IL.
The CID is the cam sensor.. I think the ID stands for "identification" to tell the computer where the cam is.. That's why they call it the cam ID or CID.
SASHO91
Zoom Zoom
San Antonio,TX
Is this on an ATX or MTX?
The atx is easy to get out..
however, the mtx is a pain in the ****... especially the rear/bottom bolt.
I found a way to get the rear bolt out really easy.
Tools:
1/4 rachet.
a few 1/4 extensions, or one long one. (youll see why)
and a 5.5mm or 7/32 socket
Pics pretty much some it up.
DSC01077
DSC01073
DSC01072
goalieman59
Learning Slowly
OFallon, IL
It is an atx, do you know if there are any detailed instructions out there.
Tools:
1/4 rachet.
DSC01077
DSC01073
DSC01072
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
its pretty much a matter of taking it off and replacing it... however if youre in my boat and that cam seal is leaking... well im just waiting to do a 60k
SASHO91
Zoom Zoom
San Antonio,TX
If its an ATX, its really easy. As you have more room because the motor is mounted farther forward.
goalieman59
Learning Slowly
OFallon, IL
What is the Syncronizer?
The ford dealer is telling me that the syncronizer is bad also. Does this have any thing to do with the Cam position sensor? If it does how do I replace it?
Jason
NoSlo
SHO Owner
Portland, OR
The only 'syncronizer' I can think of is a synchro in the manual transmission. Are you having problems getting it into one gear without it grinding? The quote for fixing that at a dealership would probably be over $1500.
Bizzy
Ask them to tell you exactly where this synchronizer is on your ATX car.
