Jeff,
The difference that was referred to is the one between the 3.0L and 3.2L engines' timing belt tensioner design. The 3.0L uses a tensioner where the initial tension is applied by a spring and locked in place by the bolt through the tensioner pulley. This set up is unable to retension the belt when the belt stretches (minutely) during its lifetime. This design requires a 60,000 mile change interval.
The 3.2L engine was a later product and incorporated a gas piston (picture below) to apply a constant tension to the belt over its lifetime. The initial belt tension is applied by the gas piston and maintained throughout the lifetime of the belt. This allows a 100,000 mile change interval for the 3.2L engine.
I have wondered if the tension of the 3.0L's belt could be reset every once in a while to safely extend the change interval to 100,000 miles. It only takes a few minutes to do. All you do is position the crankshaft damper to 60 degrees before top dead center (yellow mark on the damper lined up with the 0 degree mark on the tiing belt cover), pop the small access door off the middle timing belt cover, loosen the tensioner bolt a half turn to re-apply the spring tension to the belt, retorque the bolt then reinstall the access door.
Scott
1991, 253K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
