Cadillac Horns
Fordlover96
Virginia
The other day one of my horns crapped the bed so I decided what I would go and see what I could go find at the junkyard. I ended up taking all for 4 horns from an early 90's cadillac:nut:. Now, I installed the D and F note horns in the stock location. Just making some connectors that would connect the GM plug to my car's factory wiring. They work great. The thing I wanted to ask you guys was, how do I add the two other horns? I got a great spot infront of the AC condensor, I'm just not that knowledgeable on wiring. Ik that all for horns will blow the fuse, so does that mean I gotta install a relay or something? If so, how do I? Thanks! (I'll try to add a pic and a quick sound clip)
20140330 171624 zps42355983
Th 20140330 210046 001 zpsa1f063af
what I would do is just make a piece of wire that connects to one of the wires that goes to the horn in the stock location and put three connectors on it so that I could plug in the one horn in the stock location and then run it over to the other horns in the new location. That is already after the relay, and the horn won't draw enough current to overheat the wire, so you will be fine like that.
Dirk37
Mr. Resourceful
Washington
Hey I have the same horns! I just spliced them into the wire that goes to the stock horns. I have all four of these and the two stock horns on my car and haven't blown any fuses, so you should be fine with just these 4.
Fordlover96
Virginia
Awesome! Your car must be loud as ****! haha. Can I just ask, where did you mount the extra 4 horns?
Dirk37
Mr. Resourceful
Washington
It definitely gets people's attention / scares the crap out of them:evilgrin: I bolted them in where my airbox used to be since I replaced it with a hot air intake haha. (Don't worry I have since put my IAT sensor in the proper place)
Fordlover96
Virginia
20140331 164720 zps5c7a05dd
That really does open up that area. Lol. I ended up mounting my horns in a different location then I originally thought
