fred79
the fan motor on my 95mtx seized and burned inside the motor, the problem is that the hot motor also melted the plastic of the fan blade. so my question is will the blade from any other ford fit into the shroud of my 95 mtx, I know the shroud numbers are the same for a 95 3.8l but are the fan blades the same as well I will need to find this fast and was hoping a regular taurus' fan blade will work since it will be tough to find a SHO in a PA junk yard. thanks ahead of time.
