Broken Oil Pan Bolt
Milestailsprowe
SHO Nub
Port Orchard
Well leave it to me to break yet another part while working on the rod bearing job. So far everything else is going good, but when I went to torque down the bolts, one of the bolts broke off. I've been looking around, it seems that they're an M8x1.25mm pitch, 25mm length, but what I've got a problem is, getting the remaineder of the bolt out. About 2/3 of the thread of the bolt is still stuck up there, and I need a way to get it out. Should I drill and use an Easy Out? Or is there a better way of doing this. Thanks much for the help and support guys.
CerberuS
300 HP N/A SHO
Granby, QC, Canada
Id leave it there , if theres a good (not too muc) amount of rtv , its gonna hold. Leaksless.
If ever it leaks , your gonna see it on your parking , its never gonna empty in one shot , not to be worried.
So if it dont leak , you saved up a good amount of time and $ , if it does leak , at least you wont do it for nothing.
Thats what i would do.
Milestailsprowe
SHO Nub
Port Orchard
It's been bloody awful. Bad weather mixed with broken parts and long wait times on replacements. Though nearly done now, just putting the Y-pipe back on, gonna crank the engine after the oils in and everything's up, then start 'er up.
ScottyDsntKno
NJ
You could probably get away with a bunch of rtv and leaving the bolt out. However I would use an easy out on it and replace it. The easy out kit itself should have a chart on what drill bit to use so figure out which easy out size you need and then get your ass to Lowes and grab a dewalt cobalt drill bit of that size. Use a sharp heavy punch to put a dimple in the stud, SLOWLY drill it on a low speed with a variable speed drill. You should be able to have the stud out in about a half hour.
