Broken Front Right Spring
brandon1186
ontario
i noticed this poping noise today in the front right side of the car and my steering would pull to the right so i took off the tire and my front spring is missing a chunk about 6 inches on the second rig from the top my question whats the cheapest way to fix this can i get a nornal taurus spring from a junkyard if so how do i take it off do i need special tools ?????????
The slo taurus springs are different rates from the sho springs, so that's not a good idea.
You can replace just the spring yourself if you have a spring compressor, but consider that the struts and strut mounts are likely to need changed also, so you might do a more complete job while you are in there.
Storm-Chaser
Shit Louis
In addition to the non-SHO springs having different spring-rates, you should replace the springs in pairs, whether the replacements are used or new. Given where you live, the potential for the other spring to break is relatively high.
:burnout:
1993MTXSHO
Its a Taurus...
Jersey
heh, screw it, I broke a spring on my 93 atx, I got a used ATX spring, (atx springs are different from mtx springs), replaced it with another used one and haven't had any issues. If my other one is going to break, w/e let it break, I'll change it when it breaks. I didn't replace anything while I was in there either, I don't have the money, but if you have the money to burn by all means replace some stuff, and do the springs in pairs.:)
