Broke subframe bolt
SuperHO
Mental Patient
St. Joe, MI
Yep. Car was making some noise from that side, so I figured I'd re-torque the subframe bushings since the engine had been out recently. Upon putting some pressure on that bolt, the head sheared right of. :rant: So now it would seem I'm up shit creek until I can afford a suitable replacement. Any ideas?
Would it be possible to just slap a big ass washer on a normal bolt and run it up through there? What size and pitch is that bolt, anyway? This is my daily driver, so I gotta figure something out pretty damn quick here....
Racer X
SHO Pilot, Retired
Connecticut
M12x1.5 but don't quote me on that.
It'll need to be a grade 10.9 bolt, about 100mm or 125mm long or so.
93rev2sev
Hockeytown
Cosigned.
Same as a trans to engine bolt...but longer.
Take an 18mm and a breaker bar to the JY tomorrow and get one for $1
jthod
Mr. Goodwrench
Lincoln, Nebraska
...and don't break that one.
The fun part will be getting the rest of the old one out. I broke one on the '93 while putting the Gen 3's on. I used a die grinder/cut off wheel to take as much off as possible. Then I fished it and the plate nut out of the way.
SuperHO
Mental Patient
St. Joe, MI
Not neccessary....mosey'd my fat ass down to Ace Hardware and picked up a bolt and washer. The remainder of the broke bolt came right out through the recall hole, along with the plate......
Anyway, put the new bolt through, slapped a nut on there with, of all things, a washer from a valve cover bolt, and torqued her down. Good as new, $2.15 later.
