I noticed on the shotimes internet site in the modifications - struts and springs section the following comment in reference to installation of Eibach springs: "you will need to find a shop that is willing to break a couple of spot welds in order to align the car properly after installation, since the springs lower the car by 1 inch in front and 3/4 inch in the rear". This sounds much more invasive than I initially thought - I plan to have Eibach/Tokico combination installed this spring, and I expected that the parts simply swap in for original equipment.
Quite a few of you have probably done this modification so I wonder if you could inform me:
- is this "breaking of spot welds" necessary and is it difficult to perform?
- this implies that some fairly precise welding needs to be done after installation - is that right?
- Is this procedure simple enough that most alignment shops can do it or is there much more to the process?
Thanks in advance for responses and any pointers! Below is the shotimes link:
http://www.shotimes.com/php-bin/mod...e=article&mode=thread&order=0&thold=0&sid=180
