brake problems
Polar Pear 2004
rossford
how do i stop brakes squeling and why the **** are them and the wheeles so hot after i drove it one day i sprayed the rims and there was a ahit load od steam and i only drove about 15 min.
MeShoHorny
@dm1n15tr@t0r
NY
I see you are new here. Try the search funtion out, it serves a good purpose.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Polar Pear 2004:
Rossford Ohio????
What year is your SHO?
They are hot because something is dragging/sticking. Could be calipers, slider pins, emergency brake cable, swollen rubber brake lines, faulty booster, gunk in the brake lines, or other stuff.
Perry Toledo,Ohio
...or the brake pedal return spring is weak and not allowing the pedal to return to the released position. Does the car feel like it is dragging as if the brakes are always on? Was it only one rotor that was hot or all of them? Try lifting the brake pedal with your foot whill driving to see if the brakes are in fact dragging. That would point to the pedal return spring.
