Brake Light?
Fordlover96
Virginia
So I was cleaning my car and decided to check out all the bulbs. The left most tail light will work normally for running lights and turn signal but when the brake is applied it goes dark. Car has a brand new BOO switch. Any ideas? Wiring?
Thanks!
Fordlover96
Virginia
Tried a new bulb. The pin for the high power aka blinker or brake light is only recieving power for the blinker. The light will work correctly for blinker but goes blank for brake light.
I'm tracing some wiring rn. I removed the light out module and no change.
Fordlover96
Virginia
Well, I jiggled some more wires under the dash and after I messed with the fuse box area the light worked flawlessly!
Basically fixed itself. I don't know what the issue was!
bad connection in that area. all the rear wiring runs down the driver's side of the car on the floor.
