BRAKE LIGHT TURNS ON
SHOCLIE
SOCAL
My brake light turns on when I do hard acceleration from stop. I'm stopped on red light and when I step on it hard to asselarate my brake light turns on for a second or so. Is this normal for SHO's I have a silver 95
SHOCLIE
SOCAL
INFACT I DID TODAY HAD TO CHANGE OIL.
IT WAS LITTLE UNDER MAX SHOULD I DAD ALL THE MAY TO MAX. WHAT TIPE DO YOU USE
I would check your pads. When the pads wear the caliper pistons are pushed out further and the level of brake fluid drops.
projectSHO89
SHOless In St L
If your brake fluid is low, do NOT just add fluid.
Inspect all of your pads for wear. Your's are probably reaching the end of their useful life.
Steve
crystizel
