BRAKE LIGHT TURNS ON
SHOCLIE
SOCAL
My brake light turns on when I do hard acceleration from stop. I'm stopped on red light and when I step on it hard to asselarate my brake light turns on for a second or so. Is this normal for SHO's I have a silver 95
SHOCLIE
SOCAL
INFACT I DID TODAY HAD TO CHANGE OIL.
IT WAS LITTLE UNDER MAX SHOULD I DAD ALL THE MAY TO MAX. WHAT TIPE DO YOU USE
I would check your pads. When the pads wear the caliper pistons are pushed out further and the level of brake fluid drops.
If your brake fluid is low, do NOT just add fluid.
Inspect all of your pads for wear. Your's are probably reaching the end of their useful life.
