Brake light & oil light at high RPM's
S
SHOGIRL94
Guest
I dunno what this is all about, hopefully someone else does. When revving in neutral, my oil light sometimes flashes. And today I was going about 40mph then floored it, and when it dropped a gear, my brake light flashed a little bit. Thats the first time it did that, and I never use my parking brake so it wasn't pushed in at all. Whats up with that?
Denny
Taurus Homeland
Atlanta, GA
Check your brake fluid, the level may be a bit low and is slushing around. Top it off and look for the leak. As for oil. . ouch, doesn't that come on for low pressure, not necessarily level?
Shoman94
Maine
SHOGIRL94:
Which one, the check oil light or the oil pressure light?
