brake equalizer?
mattsho1993
SHO owner
albion, new york
what is the thing on the rear control arm called its the aluminum block with the four brake lines coming out of it.......?????????????
Westerly, RI
Bias valve. Under hard braking, when the front end dives/rear comes up, this valve lowers pressure to the rear brakes to prevent rear wheel lockup under light load conditions.
pwrshft99
il
Thought that was my problem for awhile so I tried to price check.
I was told either from a junkyard or from ford were the only way to get one.
Westerly, RI
Yep, there's no aftermarket part for this. Very uncommon failure item too.
To the OP, either get one from a junkyard, someone on here, or see if Ford still sells them.
