Brake Difference
berbo29
Sandy, UT
I have a 93 ATX that is my toy. I have a 94 that I picked up for parts. I broke a CV shaft on my 93, got on it too hard with the wheel cranked, it didn't like it. I was going to swap the two out. I discovered that the 94 has a different, bigger brake system. Can I put the 94 setup on the 93?
Phoenix
SHOHOLIC
QC , Canada
Yup , 94-95 has differant knuckles and bigger brakes.
swap everything with the 94 knuckles as well.:thumb:
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
then, from there you can get even bigger rotors by putting on 96+ brakes (expensive way) or 2001+ Taurus Brakes (cheap way)
both are 11.6" and the 94/95 is 10.9
of course you can go even bigger... but as far as stock brake systems thats pretty good
93rev2sev
Hockeytown
Can the 96-99 knuckles be used in place of the 94/95 knuckles? I'll be upgrading the black 93 soon and want the newest components. It's all the same price at the junk yard, so newer ~99 knuckles are what I imagine I'll want.
Shoaz
Studly dood
Scottsdale, AZ
No, the front suspension changed in 96 and the ball joint moved from the control arm to the knuckle. So the knuckles are not interchangeable between GenI/II and GenIII.
Best bet is get some 94-95 knuckles with ABS, then do the 96 rotor upgrade. FWIW, if you're heading to the junkyard, just get the brake brackets and larger rotors from a GenIII, they'll work (just measure the rotor so that you're not getting the same 10.6" SLO rotor).
93rev2sev
Hockeytown
SO If I can... I should get low mileage 95 knuckles, 99 calipers(with brackets), 99 rotors 99 pads
Phoenix
SHOHOLIC
QC , Canada
yup with that you would officially have the 96+ brake upgrade. Passing from 10.? inches to 11.6 inches rotors.
