Bosch O2 Sensors, Autometer Fuel Air Gauge
Rich
Cleveland
Hi:
I have newer Bosch #13942 O2 sensors on my 94 MTX, and I want to install an Autometer Fuel Air gauge. Which wire of the O2 sensor is the output signal, to connect the gauge to? Or, is there a better place to pick up the signal? This is the first Fuel Air gauge I've doen, and I don't want to mess up. Thanks!
Rich
jthomas68
Area 51
The a/f guage can`t be spliced into the 02 wire itself.For some reason it won`t pick up the signal correctly,as the instructions will tell you.It needs to be tapped into the wire AFTER the connector from the 02.
cRaZySHO.
norwalk, ct usa
If you decide to go with the guage, and don't get those adapters. You can just tap into the ECU. Thats where mine is hooked up.
bmytych
