6500rpm
So today I replaced my sparkplugs with a range colder to go with the tune and decided to grab some pictures with the bore scope of what are typically problem spots with really happy results. Just by chance, I hit 87,000mi today. I've owned the car for the last 50k miles and change my oil at 5k mile intervals with Royal Purple and try to Run 93 Mobil gasoline or Shell V Power 93 when available, I've had a McNally catch can sitting on the work bench for over a year, so this is just the factory seperator controlling blow by.
First is the valves in Cyl 5 through the 3 bar opening, both valves and cyl 2 look the same. Very little on the valves, port walls look wetish and more pronounced but it might be the casting.
The next are the pistons, cyl 3 and 4 if I remember correctly as they were down far enough to get a good view. Any carbon seems to be around the outer circumference and across the dome opposite the valve reliefs. Damn near spotless.
The last few show show the numbers on the pistons. One seems to show DA5E-6K101-AA with a smaller 1003/121301852 the other DA5E-6K100-AA with a smaller 1003/121171515 if anyone has any insight to the numbering. It was posted in a thread that the 2013 PP had better pistons if this can shed any light on the validity.
All in all, pretty damn happy today, I expected much worse. Good oil and good fuel are the only precautionary things I do. It doesn't get beat on like the cars running for time, but it gets drove the way it was designed to be driven every day of the week. Fwiw, the bore scope is just a HF Centech brand and the picture quality is much better than my Snap On which cost several time more and is only a few years older. It's a great tool to have for a lot of different uses.
