Bolts I am missing
JrodSVT
Wheaton, Illinois
I am missing a few bolts and bolt/nut combo's
I need the bolts for the starter I am missing the two bottom ones. Also I am in need of the bolt/nut combo to hold both of the control arms of the front.
I would like the thread pitch, length of the bolt(s), and head size.
any help would be appreciated.
I have mad organization skills.
Edit: I have found the starter bolts.
JrodSVT
Wheaton, Illinois
So OK I found out that the Pinch bolts are torque to yeild so they have to be thrown away anyway. SO I go to autozone and they say unless I have the original bolt then they cannot get me a replacement or I buy a control arm (which may or may not have the bolt) . So I guess I am stuck just buying some grade 8's from home depot unless somebody can tell me where to buy the correct bolts.
Thanks,
Jarod
JrodSVT
Wheaton, Illinois
thanks man I shoulda looked at Josh's site before. It is not like I don't have that book marked.
maybe the Ford Dealer will have them.
thanks again
Bizzy
Keep in mind that Josh is at the convention right now so they won't get shipped right away. Just saying that so you don't order and then find yourself in a bind because they don't come right away.
LeddZepp8687
The Keg Rider
Naperville, IL
thanks again
Go to the packey webb dealership right on roosevelt..They have them, A friend and I had to buy them for his SHO cause we figured we would break them.
Did you swap the trans out?? Im right next door to you almost and I can lend a hand, tools ect... Not to mention I pass your neighboorhood/Townhouses on an almost daily basis..
You know...I was just thinking about how I never see you or your SHO, the focus anything...But I have seen you in the mocha going down naperville road once!
Racer X
SHO Pilot, Retired
Connecticut
I'm pretty sure the pinch bolts for the knuckles to the control arms are M12x1.75, but I don't know the length.
Find me the lengths and sizes of all the bolts you need, I'll go here:
http://www.metricmcc.com/
I'll pick up the parts since they don't ship small quantities (that I know of. I guess you could ask though), and I'll ship them off to you. They're about a 40 minute drive from Queens. :)
JrodSVT
Wheaton, Illinois
I hit up Packey Webb last wednesday hopefully they will be here today and I can get those on and align the subframe. Still new to SHOs and learning so much. AllData had nothing on aligning the subframe.
I think I am going to be sad to see the car go. I put way to much time and money into it to not ever drive it regularly.
Yes the new trans is in the car.
hoboprodigy-
SMOKE
Troy, MI
/me waves benjamins under Jarod's nose
Almost done? I can be out there any day this week/weekend, the amtrak ticket is only 28 bucks to union station :)
Also, I am for sure going to be coming to the dyno thing next week in joliet, I'll have the '99 with me, you should make a thread about it :)
