Bolt size?
SHOguy 92
Duluth, MN
Anyone happen to know the info on the bolt that goes through the AC and into the bracket (the bracket that the front motor mount connects too). I don't know length or thread info on it, any help would be awesome.
Devin
3.Slow
Pacific Northwest
I could pull mine out real quick and get you the length but I'm terrible at finding out what the pitch is.
SHOguy 92
Duluth, MN
If you could find that info that would be awesome, would hate to ask u to take it to a store and have them match it unless thats no bother for you. I am missing this bolt and no sense in welding my broken bracket until I replace that bolt otherwise it'll just break again.
Jarrod
OK SHO - now in TX!
Midland, TX
*Bump*
I hate to bump an old thread, but I'm fighting the same thing right now. I thought I had the correct replacement, but the thread pitch is wrong.
I really don't want to pull the other bolt out, since I keep having a **** of a time trying to even get the bolt holes lined up.
hawkeye18
Sorta cares
Norfolk, VA
Well if you look at the SHO Engine book I posted up, it should tell you... hang on, lemme look at it... let's see... A/C Compressor to A/C Compressor bracket... is that the right one? Oh well, they're all M10x1.5. All the bolts under "A/C" anything are M10x1.5. 27-41 lb-ft for torque specs. As for length, I can't imagine you'd need anything longer than 40mm.
Jarrod
OK SHO - now in TX!
Midland, TX
Yeah.. I checked that, but was kinda lookin' for a definitive answer. But now, I've located a factory replacement, so no worries.
