Bolt 3.0 Heads To 3.2????
MI-SHOFEAR
I'LL SHO YOU
Farmington Hills MI
I have a 3.2 block and a 3.0 set of heads. Can I use a 3.2 head gasket and bolt the 3.0 heads on?? What other parts will I need?
Jeff
93superSHO
Thats a Taurus?
Minnesota
Jeff
Yes, put 3.0L heads on the 3.2L block and use 3.2L headgaskets. You will need to use all of the 3.0L accessory parts, t-belt, t-belt tensioner, t-belt covers, waterpump, alt, and all the 3.0L's belt pullies.:biggrin: :cheers:
MI-SHOFEAR
I'LL SHO YOU
Farmington Hills MI
The 3.2 is going in an ATX car. Does that mean I use all the ATX Accessorys?
Jeff
yamahaSHO
E85 whore
Arkansas
You may have a problem with mounting the accessories on the front head.
93superSHO
Thats a Taurus?
Minnesota
OH, Didn't know that. Yeah, there might be mounting issue's with the front head as Jason stated.
somedude_001
Western NY
just swap the intake cams, its much easier and a lot cheaper. of course i'm assuming you are just looking for gains.
MI-SHOFEAR
I'LL SHO YOU
Farmington Hills MI
The car I am looking at has a bad head, so I need to replace it
Jeff
