Winterhawk
1993 SHO ATX
When I Rev my 3.2 ATX by hand it revs up to about 4,000 rpm and then bogs down like a limiter or something. Is this normal? I did have a plugged fuel filter and changed it. Still the same. Will carbon in my EGR passage way cause this? Is this normal? I have 32 psi of fuel pressure after changing the fuel filter. I have new Bosch Platinum Fusion plugs and a new MASS, O2, EGR and 3 new EGR sensors and EGR valve. The only code is an intermittent 332 Lack of EGR flow. An Ex Ford Tech I worked with said it was the fuel filter or carbon in the intake. Do I need to pull the Intake manifold to remove the throttle body and any carbon in the EGR passage ways? It is a 1993 3.2 ATX with 117,000 miles. Looks to be in mint condition. I even changed the PCM with another HZ-2 PCM. Next step is looking for carbon. It runs and idles smooth but still flashes a code 332 on and off occasionally. I have a EZ Scan 1000 engine scanner with live data. I can't see anything out of place. It fails the Engine running test with code 332.
Thanks.
Thanks.
