Blue Turd hits the dyno again!
zach44102
BIG TURBO
Georgia
Put the car on the dyno to get a few base lines since some things have changed.
first pull the car made 228 (street trim)
then pulled the cutouts and made 243.5whp
The car is pulling timing about 6k and hitting 10.8:1 at WOT by 6800rpm.
So the car in 5 months did not lose any power which is good.
here is some video.
7200rpm pull
[YOUTUBE]IqVX5vn144M[/YOUTUBE]
8000RPM pull
[YOUTUBE]8f5aa90ANLQ[/YOUTUBE]
jayro
Auburn, In
Nice HP!! What did you make as far as torque?
You are making me want to add a cutout to my exhaust now. Where did you position your cutout at?
jayro
Auburn, In
I have a shosource equal length catless. I wonder what would happen if I had a cutout just after the Y. It might make it really stinky inside the car though.
RonPorter
SHO Club of America
Lake Orion, MI
I'll guess it will work better farther down the pipe, as the pulses settle down a bit.
zach44102
BIG TURBO
Georgia
Incorrect, i made the same power dumping my shosouce y pipe. I just made this one cause i wanted true duals
SinisterSHO
Rust free
630, IL
So, you made 243 thru an open y-pipe, and you think that you're a tune away from 260? There aren't many, but there are cars that dyno 250+ to the wheels with full exhaust.
yamahaSHO
E85 whore
Arkansas
I don't see 260whp happening on anything but a very high reading dyno.
intimdatr
Got Cams?
Jefferson City, Missouri
Eh 250 is possible forsure, 260 might be getting up there unless the current tune is just 100% trash. But even the 10hp is a pretty big bump. Especially if its throughout the entire RPM range.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
I made 430whp through a full exhaust, yo!
But...you probably meant NA SHO's.
Oh yeah, I made 257whp through full exhaust with a 3.0 (well, it used to be mine)
AREA 91
PA SHO SHOP
Area 91
257 WHP on 2 different dyno's 2 years apart.
Oh, and this is without a tune.:)
zach44102
BIG TURBO
Georgia
I will put up or shut up. Some good fuel, nice tune, head work, intake work as well as some headers. It will make it.
Once I turn the green car into full DD/winter status things will go full retard with the car.
zach44102
BIG TURBO
Georgia
In a nutshell all the motor has
3.2
SHOshop Stage II cams
UDP
Y pipe
lightly ported runners
BBB
Thats it, Stock heads, no gasket matching, stock intake Intake (not manifold) should be done saturday, I started on it today and should be pretty wild when its done.
