Blown head gasket?
rendyx
Buffalo, NY
Today I just had to add more coolant, which I haven't been checking lately :(. Except it was really low, and I haven't seen a single drop of coolant anywhere. Is this what I hop it isn't?
rendyx
Buffalo, NY
I don't think its the HG, there's no coolant visible in the oil. As for the water pump, it might be trash. I know my SHO still has lots of stock parts, which are slowly failing. But I'll have to give it a look, and see if it looks like its leaking or something.
<small>[ August 18, 2002, 10:33 AM: Message edited by: rendyx ]</small>
SHOemup
Dalton, PA
When my waterpump went, there was not one drop of coolant either although I could smell it when I shut the car down. If it is the WP, change the CPS too because coolant leaks out of the pump, onto the CPS and then onto your exhaust where it burns away leaving no sign of a leak. You may be able to fit a little mirror down by the timing belt cover making the weep hole visible. If there is coolant visible, then it's your waterpump
Brad kirk
