autobahnsho
SHO Victim
Scenes from our previous episode:
http://www.shoforum.com/showthread.php?t=26145
Well, last month when I was driving to go test-drive my van, I knew I should take it easy, because of the smoke problem.
--you can skip this part if you want---
BUT, it's a 30mile drive on the autobahn. I was nice on the way there, hitting 100mph only once.
On the way back a US-plated 2000+ Mustang GT convertible went blowing by and I couldn't let that happen, now, could I? So I followed him at 120mph for a while. He lost me a little on the straights but he backed off on the curves so I kept up for around 10-15 miles.
THEN I get a HUGE cloud of smoke out the back around the same time the car makes this awful ticking/thumping noise under the hood, and all power was gone.
As I was waiting for the tow truck I was looking under the car- there was a small amount of water leaking out. Maybe just some condensation off the A/C? When we pulled it off the truck there was a small puddle of oil under the block.
I let it sit until today, fearing a spun rod bearing.
Today I figured, maybe it was just a big oil leak and the timing belt or something easy broke. So I pulled the tb cover off, the belt was nice and tight.
The INTAKE was full of AntiFreeze and Oil. To the point that some had gotten on the air filter!! I popped off the front valve cover, there was a little antifreeze near where the pcv hose comes in.
So, either something broke in the Throttle Body, allowing antifreeze into the engine, or I blew the headgasket??
Does the headgasket have anything to do with antifreeze in the engine?
I'm assuming that if that much antifreeze got in, I still need to check the rod bearings for damage. Along with changing oil and antifreeze.
THANK YOU for any help that you can give me.
to the members of the SHO Forum.
