Blown Gas Tank Seams
Mechin43777
Roseville
I have a customer that has a 94 SHO and she is getting ready to put the 3rd gas tank in this thing. It keeps blowing apart at the welded seam.
We told her she might be better off to go with some type of fuel cell but we are having no luck finding one. Any help would recieve alot of gratitude.
PAracer
West Chester, PA
There must be a problem somewhere else in the system. Take a look at the gas cap (it has a pressure relief valve), fuel lines, fuel pressure regulator, etc.. I'd bet on a fouled gas cap.
rangerj
Brunswick, Ohio
Do a complete analysis of the canister purge system, and as recommended above check the gas cap for pressure relief. The tank is more likely "imploding', rather than "exploding", from vacuum forces.
If the tank is being pressurized, possitively, what is the source of the pressure? Has the car been modified? Check the fuel pressure regulation, but this is an unlikely source of the problem. rangerj
pjtoledo
'ol man in the SHO
toledo,ohio,usa
The gas cap is supposed to hold pressure in, no fumes or vapors are supposed to get out through the cap. It will let air in, somewhat, but not out. Fuel will expand during driving, heat from the exhaust, the pump, vapor pressure,whatever,,it will expand. The expanding vapors are supposed to escape thru the vapor recovery tube and be absorbed by the canister. Whenever the engine is running the canister purge valve does its trick and engine vacuum is applied to the purge line,,sucking the stored fumes from the canister, and some fumes from the line and tank. Problen is,, normal engine vacuum will quickly collapse the tank. To prevent this, there is a small restrictor tube in the purge line that restricts the amount of air being sucked from the line. The gas cap will allow some air into the tank remember,,the restrictor tube is to prevent more air being sucked out than the cap can allow in. The restrictor tube is inserted into the gas tank purge line along the bottom of the radiator. Just a small piece of plastic tubing. The hole inside it is less that 1/16". Make sure it's open, but don't enlarge it. If it is plugged you will get a pressurized tank, if the hole is to big you may collapse the tank.
Perry
Mechin43777
Roseville
THANKS FOR THE INFO. WE FOUND THAT THE LAST GAS TANK WAS UNDER WARRANTY FROM FORD SO SHE TOOK THE CAR TO THEM. BUT THANK YOU ALL FOR RESPONDING SO QUICKLY. I THINK THE NEXT CAR I BUY WILL BE AN SHO
