JRA2000TL
The Complainer
I've noticed if I let my 89 sit for several days and then get into it and attempt to shift through the gears, whether the car is off or on at idle, it is VERY difficult to get into the gears (any of them) and still grinds in reverse. If, however, I start driving the car and get it moving, the shifting goes back to normal--goes through all gears, even reverse without grinding or anything. What's the deal? Worn blocking rings, bad clutch, etc.? Car currently has Valvoline MaxLife ATF in it. Should I try Pennzoil synchromesh? I'm pretty sure it has the original tranny at 256k. Being an 89, it doesn't have the updated fiber blocking rings. Just a case of an old, worn tranny? Like I said, it does this after it's been sitting....but once I start driving and get going, it smooths out.
