Blending e85 and e10
steelgiant5
Looking to see if anyone other than @SHOnUup4 is using a blend of e85 and e10 in their sho? Torrie told me to make sure frp stays safe because of the temp outside and adding the corn gas.
Sent from my iPhone
steelgiant5
Yeah, I just found a thread with an assload of info on ecoboostforum.. Reading that right now
Sent from my iPhone
SHOnUup4
SE MI
To anyone reading this...just don't surpass the 20% barrier.
Not much in the terms of gains beyond the 20%.
EcoBoostSHO
Minnesota
Agreed! And as noted above cooler denser air requires more fuel...E85 blends can tax the fuel system as it is so keep an eye on fuel pressure and I would log to make sure your car is happy.
yamahaSHO
E85 whore
Arkansas
Should be able to get WAY more gains above 20%, but that's provided the system can proved the flow needed. E70 and up is where it's at! :)
SHOnUup4
SE MI
That's the issue...not enough flow available to take advantage of the higher blends safely.
BamSHO
South Williamsport,PA, US
Someone needs to step up and build a bigger capacity DI pump. That's where the issue is period. Don't say bigger injectors, cause you still need a bigger pump to feed them.
92BlackGT
OKC
I run some E with 100% 91 and there is definitely a noticeable difference even on the stock tune compared to 100% 91 or E10 91. I need to get off my buns and get Torrie some datalogs to take even more advantage of E!
BigB15
GA
I switched mine back to E30 last night but wasn't seeing consistent datalogs.
I'm going to send them over to Torrie today and see what he thinks.
SHOnUup4
SE MI
I'd try a lower mix at 20% to start logging with
BigB15
GA
Yeah, I think I'm going to have him just set it at e20 and go with that.
The temps are going to be in the low 40s Friday night so it will be happy with the cool air
