Eastcoast SHO
SHO
ok i went through hours and hours of reading threads from searches but i am still a litlle confused about this one.....the other day i was going down hill around 50mph come up over the hill saw stopped cars put on my brakes, as luck would have it broke 2 solid lines and one front steel braided line, swerved over into on coming traffic stopped about 200 yds from the time i actually hit my brakes, so i changed all the lines and got new braided lines, bled the brakes pedal is still mushy, right rear dribbles out, ive been seeing a certain sequence on which tire to bleed first and so on, but i have also seen that if you run the master cylinder dry(which happened during loss of brakes) you must bleed that as well, how would i bleed the master cylinder and do i need to bleed my abs if they do not work? basically how would i bleed the whole damn thing the right way? thanks guys
