HyperMikeD!
FordBastard07
Yes I did a search first but didnt find the answer I needed.
So...I just did a brake upgrade on a gen 1 and ran into a problem. With all the brakes bled and no air in the system the pedal pressure in manual mode operates as normal. Start the engine and press the pedal it goes to the floor and sticks. Ive never had to bleed the ABS before but I think its either that or a bad master cylinder. But why would it work in one mode and not the other ??
Thoughts ? Suggestions ?
TIA.
TIA.
