black ignition wire to the starter solenoid "92"
kevingotashotoo
200 or so ponies
peterborough,ON canada
probably a dumb question, im not getting any power to the thin black wire to my starter solenoid, (thats with the key in the start position with the clutch interlock bypassed...still no juice at that place....
so to the question is it possible to just hook 18gauge wire to the power distribution box, run that wire from the box inside my car hook it up to a push button switch and that wire from there back out into the engine and up to the solenoid, will this work?
kevingotashotoo said:
wait a sec, am i suppose to test that black wire with the key in the cranking position?:oogle:
Well, DUH!
When else is the starter relay suppose to energize...????
kevingotashotoo
200 or so ponies
picture of my starter
do i have this hooked up properly?..........the two + cables to the first terminal post you see
nothing but the braided wire from the starter to the terminal post behind the first one...
i was being an idiot when i took off the starter and the wiring, i took it off than left til' the next day to put it in so i think i might of forgot how it goes
help appreciated:hail:
Ishodu
Good to hear, now all you got to do is get that POS fram oil filter out of there.
kevingotashotoo
200 or so ponies
the motomaster?........yes i did an oil change right afterwards got a plastic bag and tucked it over my starter so when i removed the oil filter the oil would not touch the starter
now i have a "FRAM" on there and some fresh new oil
Minnesho
i was wrong
MinneSHOta
spray some degreaser on that thing!! I'm currently running a mopar oil filter lol.
Ishodu
whats wrong with fram?
IMO the only thing they do is keep oil from leaking out there. At one time they were good filters now they are made so cheap that well there just crap. Try some searches.
kevingotashotoo
200 or so ponies
true true, i never knew that,whats a good filter?
Ishodu
Pretty much anything will do thats not attached to fram. Compare the part # and the overall appearance. Many manufactures use fram filters. There is only one other one at crappy tire its a purealtor and it says so on the box, it might be a valvoline or something, other than that car quest and NAPA IIRC sell wix filters that do a good job as well. You can always go dealer too.
kevingotashotoo
200 or so ponies
kk, might aswell give it another month, i only put 100k a week on my sho anyway, but i do want a filter that actually does its job
thanks for the input
bmytych
