Big Timing tensioner problem. please help!
Tyler
New Mexico
Okay Ill let Mike know.
I got a response, Thanks for the help. And I assume the order to replace these parts goes piece i have left over, washer/pulley, special washer, and then nut. Will this nut have to be torqued down to a specific pound or just regularly tightened, as in just tightened until its super tight/ until I'm satisfied with how tight it is?
Terrorizer
SHO or ****
So does that mean i could get the nut that holds on the bearing and pulley? Because im probably going to need one since mine is gone.
I'm sure you could find the nut at a local hardware store.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
I have been able to tighten it down till its tight and been fine.
thatSHOguy101
