Tyler
If that's what its even called, i was driving my 89 ford Taurus sho mtx and i heard something fly from under the hood, so i pulled over and checked it out (the check battery light came on btw) i looked around and noticed a pulley was gone( the timing tensioner pulley) and now all that is left is what i think is a bearing, or part of a bearing. the bolt is gone and the pully is gone, obviously. The belt is torn slightly on the side next to the engine in various places. The bolt that holds it on is loose as well. and I don't exactly know what I need to do to fix. I know I need parts but what parts, and how do I fix it? I'll be putting pictures up in about an hour to help clarify anything. I've read other posts on what i think is this but im still unsure. The fist picture is the bolt were a pulley and bolt should be, the second picture is what was still on the bolt, I'm guessing it's part of a bearing, and if this piece is supposed to be greasy/lubercated its not. its bone dry if that helps with anything.
