best way to add tranny fluid
Mike Stitzer
PA
My shifter has been feeling notchy lately and I'd like to check the tranny fluid. Do I just open up the horizonally mounted cap and add fluid until it starts running out? Also, what's the best way to do this. With a syringe? 95 MTX by the way.
Mike
T
ThatSHOkid
Guest
when erik (sho91mtx) did mine he made his own great contraption that works wonders. he had a funnel with soem tub0e attached to it. hopefully he will see this thread and reponse. kudos to erik for making it and also no spillage on my driveway because my mom was happy about that.
1993 White/Tan SHO MTX 96k Miles
[*] Eagle Super White Headlights ** American Products Company Super White Reverse Lights ** Hibrid Double Watt Super White License Plate Lights ** Colgan Custom Bra From Cincy SHO ** Gen. 2 Font "SHO" Windshield Banner ** Superchip Performance Chip ** Blacked Out "SHO" Lettering ** Sho Shop Y Pipe ** Coneless & Boxless ** K&N Filtercharger ** Blazertech Super Clear 55w Foglights ** Ventshade Sunroof Wind Deflector & Vent Guards ** GTS Headlight Blackouts ** Sony 10 Disc Changer ** All Possible Options
[*] Coming Soon: Tinted Windows, Sub Frame Connectors, Strut Tower Braces, & A Sig Pic!
[*] The Driver: Jay/Jason/Hubes
[*] The Car: Zsa Zsa
[*] The AIM Screename: KingPin641 (I am a NESHOC member)
***"Drive it like you stole it!"***
SLOSHO89
San Luis Obispo, CA
I did the same thing also. Just get a small funnel and a peice of clear hose. I cut a small slice in the hose then slipped it over the end of the funnel. Wraped it with some duct tape to make sure it wouldn't come off and that was it!
Use your finger to check the level. It should be about 1/4 inch to 1/8 inch from over flowing(pretty sure, any one back me up?).
Good luck,
Efren
Oxford White '89 SHO
QUIKSHO Plates
SHO SHOP Y-Pipe
Slicers, SHO+ hood and spoiler.
Web Page www.geocities.com/web_page66/
E-mail, [email protected]
AIM; SLOSHO89 I like to talk SHOs:)
gregr
Orange County, NY - USA
Yes. A small funnel with a length of hose works very well. You may consider adding a drain plug on the tranny as well. This was one of th ebest and easiest mods I performed to the car.
Found the procedure on SHOTimes.com
Greg Raciti
SHO Forum Webmaster
93 Emerald Green MTX
Performance Plus high flow stainless Y-pipe
Scott 2.5" Mandrel Bent Stainless
Exhaust with Edelbrock mufflers
SHOShop Cold Air Induction
SHOShop Underdrive Pullies (to be installed)
Romar Enterprises Subframe Connectors
SHO NUT Performance Aluminum Subframe Bushings
24mm front sway bar
26mm rear sway bar
Energy Suspension poly bushings
SHO SPD
SHO member #480
Naples, Florida
What is the best way to drain the fluid without a drain plug??? And also what kind of fluid do you put back into it? ATF??? doesnt seem right, any ideas?
1989 Titanium pearl
CAI- Thanks to justinrsho
K&N cone filter
G-tech times
0-60....6.61 sec.
1/[email protected] MPH
"Dont tell me, SHO me!"
hanshua
Blue Mounds, WI, USA
I'm pretty sure it wouldnt be ATF.. Usually manual transmissions take GL-4, but I'm not an expert on the SHO MTX seeing as I have an ATX..
-Justin
95 ATX
K&N Silencer-Coneless, SFC's, two 12" kenwoods w/ 600watt amp and sony CD, CincySHO Cowl Hood, Removed secondary silencers, TPR bushings.
Comming Attractions: New 17" wheels (need rubber for them), SS y-pipe, new springs to fix my sagging rear, 24/26mm sway bars, Strut Tower Braces, Yamaha Badges :)
Rob94
Northbridge MA
Yes....the stock transmission calls for Ford Automatic Transmission Fluid......Mercon or Dexron II will do just fine.
RStalveyARFF
too many shos
Georgetown, MA
to drain most of the fluid, get under the car and look on the forward facing part of the casing, close to the subframe. Say you were looking at the transmission from the driver side. There is a plug at around 7 or 8 o'clock and if you undo that (13mm) it will drain your fluid.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Be EXTREMELY careful when useing the 13mm bolt to drain tranny fluid!!!! It secures the internal shift gate, if you move the shift lever when this bolt is out the tranny will have to be opened up to put the shift gate back in it's place. Mobil 1 synthetic ATF tranny fluid works fine in these 5 speed trannys.
Perry Toledo,Ohio
gregr
Yes,
Listen to Perry. That bolt does indeed hold the shift gate. Mover the shifter while that bolt is out and you can screw yourself.
installing a drain plug atthe bottom was a piece of cake.
Also, as stated, the MTX does use ATF. I have used both the expensive RedLine MTL manhal tranny fluid, as well as cheapo organic ATF. I think the cheap stuff felt better!
Greg Raciti
SHO Forum Webmaster
24mm front sway bar
26mm rear sway bar
RStalveyARFF
too many shos
Georgetown, MA
uhhh, we must be talking about two different bolts then, because when I had my tranny apart during my clutch, I checked it, and the gate was secured by another bolt.
shobroooo
