battery light?
.RaMpAgE.
Las Vegas, NV
Im pretty sure the alternator is gone since the batt light came on cause the battery's good checked voltage running was like 12 or 12.6 i cant remember im sry went to autozone had it charged just in case since i dont want to be stuck lol..... any ideas its kinda weird though case when u first start it the batt light didnt come on then at about 1800 rpm it comes on then after a while it just stays on, i did notice twice today when i just sat there it acted like it went through a electrical cycle and then the light went away then once i started to drive again past 1800rpm it came back on is there a charging relay between the batt and the alternator by chance? im just guessing the brushes are worn or loose.
cause i see a rem alt on ebay for like 75 shipped!!
jmpSHO
Massachusetts
Did you check the voltage when the car is running? At idle it should be around 13.5-14 volts.
Phoenix
SHOHOLIC
QC , Canada
Its way too low , the standard at idle is 14.4 while 12 (plus or minus .5) when engine off.
Replace before it kills your battery too.
