ICEMAN007
Hey guys, I ran into a big performance loss at WOT about a month ago. You guys reccommended pulling the MAF Sensor out and spraying it clean with some MAF Sensor Cleaner. When I pulled it out the 2 little sensors were pitch black and full of carbon so when I sprayed them off and re-installed the MAF, I noticed instant improvement. But after driving a few weeks later, I noticed the same problem at WOT. I again pulled out the MAF Sensor and to my surprise the little sensors were shiny silver and clean as a whistle. Today I pulled off the plug to the MAF and drove it around the block to see what would happen. Obviously the check engine light is on but to my amazement, as I manually shifted through all 5 gears, I have regained all lossed power and responds the way SHO's should at WOT. What the **** is going on? Any help or advice would be great. Thanks!
I had the exact opposite symptoms, but it sounds like maf to me... Ever die at a light or unstable idle? My maf problems showed a range of symptoms.. I plugged in someone else's, and she ran great.. only $89.95 at vato-zone.. Great investment to make (lean is BAD o.k.?) I am going hunting as soon as it's dark.
