Bad creaking from the front left
LiLGhettoSmurf
Owego, NY
I have a bad creaking noise coming from my front tire, If I go over bumps or take turns I can hear it, Or when I push down or sit right above my left front tire I can hear it, Im not to intelligent when trying to diaignos(sp?) things. Any one know what it is?
duckrider
ohio
check and see if your coil spring is broke, look at the very bottom coil, mine was making that kinda noise right befor it give lose and fell on the tire destroying the tire and the swaybar link .....
imlosthere
Oklahoma
Just have someone push down on the fender and "bounce" the car while you get down on the ground and find the noise. You should be able to touch the suspension and feel the joint that is making the noise. Just don't get your hand stuck or worse...
