Mike93
Go Sabres!!!
So I've been having difficulty shifting for the past few thousand miles. When I swapped the mtx into the car I went with a reman Autozone clutch...it was supposed to be a temporary clutch since I wasn't 100% confident the swap was going to work.
A few thousand miles into it and it shifted fine. At about 10000 miles of pretty light driving I noticed difficulty upshifting. If I was higher up into the rpms (above 4000ish) I could shift okay. But from say 2000-4000 it would take a few seconds to engage, I had to wait for the rpms to drop down to idle. At this time I noticed I was severely down on trans fluid so I filled that back up, figured I may have got the trans hot and toasted some synchros???
So I put in a trans from a friend that was in solid shifting condition...same problems with the shifts.
I have adjusted the cable several times, as well as replaced the clutch cable about 5000 miles ago.
It feels like when I push the cluth pedal it's not fully disengaging the clutch, but several clutch adjustments later and it still won't go. I'm beginning to wonder if the pressure plate is just getting weak and not allowing the clutch to function properly...seeing as this problem has occurred with two transmissions and I really don't drive this car all that hard.
Thoughts???
Thoughts???
Let up on the clutch pedal enough to get the car to BARELY CREEP. Keep your foot there and pull out of gear into neutral. You will feel the synchros let go. Go NO further. Thats the spot. Return the selector to neutral, stop the engine, let up on the clutch pedal and start over from square one but this time, leave the clutch pedal pinned to the floor.
